alternativeclim
Apr 30, 2013Explorer
I can actuate the solenoid manually with a battery charger applying power to the small side post terminal. The solenoid will click and if the engine is running, the alternator current flows to the battery.
The oem wire coming from the fire wall to the side post terminal has no power, even if the engine has been running for a half hour...I’m thinking that it may be wired into the ignition switch since none of the fuses are bad at the fuse box, but if that’s the case how come I don’t have any other issues...
