BFL13
Jul 08, 2015Explorer II
The Paramode converter with Temp Assure has temp comp but no type of battery settings. In the Paramode I had a couple years ago (it fried itself somehow) the "nominal temp" was 60F rather than 77F like some of the other specs.
Its temp sensor goes on the ring lug that goes on the battery on a long wire from the converter.
When the converter goes inside the trailer and the batteries are up front, you have a heck of a time routing that long wire.
The portable charger, VEC1093DBD, has a built in temp comp, but I don't know what "nominal" is. It definitely works. You see it doing higher voltages in the winter than in the summer. It doesn't actually have Float stage though.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Jan 18, 2025
