Shwthomas1975's avatar
Apr 25, 2018
Battery toast?
Good morning!!!!
Just finished unwinterizing my little hybrid camper yesterday and plugged it in to charge up the battery. But...... won’t hold a charge. The inverter/charger is working as everything works when plugged in and if I put a meter on battery terminals when plugged in it reads over 14. But unplugged it reads .1 or so. Can a battery not take any charge? I can see maybe a faster discharge, but none at all? I have been reading and I guess from now on I’ll disconnect the battery and bring inside for winter.
Is there a way to verify the battery is junk before dropping cash on a new one?
Thank you so much for your time. :)
  • If you have 120VAC available close to where you park, why not leave it plugged in? A decent converter will maintain the battery in a fully charged state.
    Also, if you have a stand alone battery charger, you might take the battery out and try charging it with that. Most converters are not capable of bringing a totally flat battery back to life.
  • Or make sure the battery itself is getting 14 volts,....by putting the meter probes on the lead posts of the battery, not just the cables connected to the battery.
    But otherwise, the battery sounds like toast :))
  • Thank you. I didn’t know they could test that. I’ll call the local advanced auto.
    Lesson learned. :)
    Appreciate the advice
  • It probably went dead over the winter and then froze. Discharge battery will freeze just like regular water, and then damage to the plates may occur. Take the battery to an auto parts store most to free testing but it sounds like it’s ruined
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
