3_tons
Feb 16, 2022Explorer III
The problem of which you describe tends to point to the common effects of voltage sag… Lithium (due to a nearly flat discharge voltage profile) is ideally suited to overcome this common problem … Understand too that cold temperature charging (charging at or below 32f) doesn’t prevent continued discharge down to about -04f… Temps can often rise by the early afternoon, and LFP’s far deeper DOD (depth of discharge) over Lead Acid types will often see you through to the next available harvest cycle…Yet some manufacturers offer LFP’s with charge protection shutdowns and some with built-in heating elements that activate when charging, and you could always opt for a battery heater blanket, or even an indoor mount, thereby repurposing your battery box for additional storage (what I’ve done)…
3 tons
3 tons
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
