3_tons
Feb 16, 2022Explorer III
Quint Da Man wrote:WNYBob wrote:
When up grading batteries check to see if your converter is up to the task of charging them. AGM and Lithium batteries take different charging rates and voltages! Yes, another cost, but don't damage the new batteries.
Thanks I'll look into that.
I was just up in North Tonawanda this weekend. My rig is at Colton RV as we speak. That's who will be doing the upgrade if I go forward wit it.
Be advised that if you have a Progressive Dynamics charger, you might simply add their optional Charge Wizard dongle… For Lithium, simply switch the dongle into the 14.4v Boost mode / no need for an upgrade…
BTW, in nominal terms, one 100a/h LFP is roughly equivalent to two Lead Acid batteries…
3 tons
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
