theoldwizard1
Feb 16, 2022Explorer II
WNYBob wrote:
When up grading batteries check to see if your converter is up to the task of charging them. AGM and Lithium batteries take different charging rates and voltages! Yes, another cost, but don't damage the new batteries.
If you need to upgrade the converter then now would be a good time to get rid of it completely !
An inverter/charger/automatic transfer switch can replace it.b Easy to install and even easier to use !
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
