Supereri73's avatar
Supereri73
Battery Upgrade
So, I just bought a new 5th wheel toyhauler. It currently has a single 12v battery. I want to seriously upgrade the battery capacity.
I had 2 Costco 6v golf cart batteries in my last rig. I think I want to go to 4 batteries in the new RV. I'm interested in the Trojan T-1275 (12v 150AH at 20hr). I can get them for $158 each plus core locally.
I have space for 2 batteries on each side of the RV. This means I would have to run cable between the sides, which looks like it will be fairly easy.
Some more variables. I currently have 150 watts of solar with a Zamp charger. Looking to upgrade to ~450 watts. I also have a 2k watt pure sine wave inverter.
Here is how I *think* it should be wired.
This would require 3 wires (1 power and 2 ground) to the other side of the RV. I'm thinking some like 1/0 or 2/0 for these runs.
So, my questions are these. Is it ok to have the battery banks spread apart like this? Is 1/0 big enough?
  • Yup, that is balanced and the best way for 6 six volt jars.
    Supereri73 wrote:
    I think this shows your last suggestion. Please let me know if I still don't have this.
    Thanks to everyone for all the GREAT feedback on this!!!!!!!
  • Heel and a toe and a heel and a toe, and slide-slide-slide.
    One of the bigger mistakes I see with golf car batteries is a tendency to want to bolt a large lug down onto a relatively tiny post. Unless they've changed designs, a well positioned automotive type clamp is a hundred times better. Or to prove the point, load a thousand watt inverter heavily for a minute then run down to the batteries and feeeeeeeeel the energy with an almost burned finger tip. High amperage versus the stud contact area do not jibe. Not even close. This is why standard issue for an L-16 is an L-pad post.
    For lesser amperage, no sweat. For big inverters, sweat...
  • Something else to throw in the mix folks.
    Should their be a 300Amp fuse between the inverter & positive post?
    I have zero gauge between the positive inverter post and the batteries BUT that &^#$ fuse heats up! Not hot enough to burn but hot. Not sure what I'm loosing thru it. Ideas?
  • I would sooner build a custom battery box to vent outside vs pull wire between those two small compartments. Maybe go back to the 12v or even L16(6v) if you want to go big. Consider AGM and skip the venting in the large compartment.
    Absolutely there should be a fuse or circuit breaker there. If you think the fuse is getting hot, consider what a short circuit would do; several thousand watts being dissipated is no laughing matter.
    You could measure the voltage drop across the fuse under load pretty easily with a decent voltmeter. It might also be good to check that the connections to the fuse are good and tight and clean; quite possibly some of the heat isn't due to the fuse itself, but due to a resistive connection there. (That would incidentally also tend to cause the fuse to blow earlier than it otherwise should, since it's basically vaporized by heat when it blows.)
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
