peirek
Jun 28, 2018Explorer
Battery Upgrade
First let me set the stage. We boondock 1-2 weeks a year. The rest of the time the trailer is plugged into shore power either in storage or at campground with hookups. We have one house GP27 wet ce...
time2roll wrote:
Does the WFCO ever go above 14.0 volts? 250 watts solar and the existing battery(s) would do a lot better. Maybe even leave the generator at home.
Lifeline (AGM) specs say charge at 14.4 volts. Trojan T-105 (flooded) says 14.8 volts.
Match the voltage to the actual batteries you get for best results.
Either way you probably need to replace the WFCO if using the generator.
