full_mosey
Sep 01, 2015Explorer
BFL13 wrote:
Your "morning voltage" is close enough to make your decisions while camping, and once you get home you can charge the batts up fully to 100% and "baseline SG", then put them on Float till the next time camping.
Yes, this a thousand times.
For late sleepers, there is a Turnigy that will hold the lowest Volts overnight and display that info later. Reset it each night and you can observe the overnight low Volts trend at your leisure.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
