brulaz wrote:
Wiz- My question was about the Battery V drop. Not the source of the current draw. Thought the info was sufficient.
Mex- Think the bubbles were uniform, but will redo this several times and see what happens.
Vulcan- LiFePO4 advantages to me are:
Extreme light weight and configurability
Can be left at 10-90% SOC indefinitely
Relatively constant voltage
AGMs are much heavier and apparently do not last long when only partially charged for weeks. IOW a pure solar system without a generator is not good forAGMs.
But there disadvantages with LiFePO4 as well
Well simply staying the wattage draw.."I have a 256w load" my village drops appears to be too much... it's simple and straight forward
But saying " I'm running my fridge on inverter" with no distinction
Makes me and possibly others think residential 120v fridge...
There is lots of talk about that topic and inverters and batteries
Very little about running an RV fridge on inverter
And the avg conversion to residential does not use that much power
Sorry for getting confused about what you were doing
