Gjac
Nov 04, 2020Explorer III
profdant139 wrote:What kind of tester did you use? When I checked mine with one I had from Walmart my cells were always uniform also. Got another with floating balls and got the same results. They both read about 1.265. When I checked distilled water I got the same reading. My batteries don't slide out so it is difficult to get a tall one in there to test. So unless you can get in with a good hydrometer like a Frese you may not have an accurate reading. Check it with a glass of distilled water and see what it reads. Having said all that my cell closest to the positive post was also low. It also had a reading of only 1.5v with the charger on. All the other cells were about 2.5 v. Running an equalization routine fixed this problem.
The specific gravities of the cells were uniformly good, according to my tester.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
