- 2oldmanExplorer III've done 'welding' when hooking up batteries. It takes a split-second to destroy a battery post bolt. I can only imagine the firestorm that OP hookup would do.
- tenbearExplorer
All I could afford wrote:
If any of you subscribe to motorhome magazine, check out the December 2015 issue Page 68 to see the actual photo and accompanying article!
Amazing! I thought Motorhome Mag was better than that. I wonder if anyone read that and tried to duplicate it.:h - MEXICOWANDERERExplorer
Chris Bryant wrote:
I do wonder what the outcome of that would be- would the batteries or cable melt first? That's kind of unstoppable force against immovable object.
Real Experience 101
A portion of the lid blows off when a cell explodes. One or both batteries. Sounds like a loud POP. - All_I_could_affExplorerIf any of you subscribe to motorhome magazine, check out the December 2015 issue Page 68 to see the actual photo and accompanying article!
- Old-BiscuitExplorer III
rjxj wrote:
I had too look twice to see if it was a trick. Depending on your goal that could be an excellent set up. First set up a video camera then get quality goggles and a hazmat suit with kevlar. If they get past the molten lead and blinding blue arc as the last connection is made and it did happen to weld in place the ensuing melt down would will make excellent you tube material.
The best I have witnessed was 48 volt 4800 pound fork truck battery 4/0 cables shorting. It's like creating a blue sun and molten copper and lead is blasting out. It's wicked. There are ungodly amps when shorted and they aint taken no for an answer. Something has to give.
I would hate to be the guy that had to make the last cable connection :S
Best melt down I have witnessed was at 2AM when a 220KV Line Disconnect started disintegrating.
Worn spot on end, salt air, started tracking then started arching.
Small bright spot that grew into a very large green eye blinding arch that didn't stop until 15' of cooper disconnect had been consumed.
Gravel underneath was fused together with large pool of melted cooper
Very impressive on a moonless night.
Made for a very busy end of shift with 2 Unit trip---next 5 hrs flew by :B - azrvingExplorerIf the batteries are jb welded together the two cables could then serve as a carrying handle and hand warmer.
- wolfe10ExplorerAs a minimalist, I am fine with it-- just have to remove EITHER wire and it is a standard 12 VDC battery bank. And, that leaves you with one fine interconnect cable when you add another pair.
- CA_TravelerExplorer IIIAnd I was just trying to keep my Briggs and Strattons running. :)
- azrvingExplorerI had too look twice to see if it was a trick. Depending on your goal that could be an excellent set up. First set up a video camera then get quality goggles and a hazmat suit with kevlar. If they get past the molten lead and blinding blue arc as the last connection is made and it did happen to weld in place the ensuing melt down would will make excellent you tube material.
That battery set up is more dangerous than bajaing cars and trucks out in a field until they break something then shove a jack or a rock on the accelerator pedal until it blows. I've watched them spin a tire at full throttle until it catches on fire and burns the whole car.
Small engines and things like snowmobiles are a lot of fun to destroy. Securely raise the track off the ground and wire the throttle. They will blow the belts off and destroy the shields and hoods then the engine is no load and scatters it's guts. We fed an old jlo twin cylinder snowmobile engine sheet metal screws and it puked real quick. :) I've had briggs and strattons bolted down running wide open and start feeding it sand. Drain the oil and run it wide open until the rod blows out the side of the crankcase. It was my education in failure analysis. I had an interesting childhood out in the oldmans garage. :) - All_I_could_affExplorerAnd to make it worse, Motorhome magazine was praising this for it's neatness!
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
