kamperdog wrote:
So my battery is dead again. Unplugged to the shore power to see if the battery was ok after the winter and within and hour and a half it was down to 1/3. I've always been getting the EverStart RV/marine batteries from walmart. I haven't checked the water level in them yet either. (I don't think that would matter at this point) Its the 29 size.
What type/brand would you recommend I try this time?
First does the name "EverStart" suggest anything, like that is a STARTING battery, not a DEEP CYCLE battery?  I used to buy a new MARINE/Deep cycle every season.  You need a DEEP CYCLE battery.
if it will fit try a GC-12
Also, Come fall, when you park, Fully charge the battery, Identify with red/black tape or paint the positive and negative leads (red for Positive) and remove the battery to a bench (Set it on a piece of scrap wood or several thicknesses of corogated paper (2 or 3) so if there is any liquid leakage it destroys the scrap, not the bench) hook up a Battery minder (TM) or Battery Tender (TM) and keep it charged, This is all important.
Finally, What converter do you have? (Some of them kill batteries fast)
Finally. GC-12. the GC stands for "Golf Car" it is a 12 volt deep cycle Golf Car battery.
Footnote:
Was watching a presentation on Lithium IronPhopsate batteries today, Look interesting but at $10.00 per amp hour, Still not ready for prime time RV use.
