- RJsfishinExplorerPeople badmouth the OEM battery monitors, why, I don't know ! Any batt monitor beats nothing. If a battery monitor shows the batter voltage into the charging category, (above 13 volts) you can bet its charging !
But that's assuming the monitor reads zero when off. :( :)
OP, the readability of your post, sucks - wolfe10ExplorerTemporary "fix" for bad isolator. Mark and remove wires from wire to one battery's large lug and install it along with the other battery's lug. You have effectively bypassed the isolator.
If this doesn't work, you can combine alternator output and battery charge wire. - HatyaExplorerOf course my meter is at home.
I'm running off the gen right now. My battery status meter shows charging with the gen on is it truely charging? - tvman44ExplorerYou need a VOM aka volt meter. :)
- Mandalay_ParrExplorerSee if you can find an electrical person with a meter who can help you.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
