- AlmotExplorer III
MEXICOWANDERER wrote:
How much is the TOTAL including shipping? I cannot access the Northern Hydrofunk website down here.
Mex, shipping to where you are, is a big unknown. Within 48 states expect S/H $8-10, total $30.
I like this:
"...automatic high frequency pulse desulfation (not high voltage), which helps extend the life of a battery up to four times over its normal life".
Gotta put my car battery on it, let it live 20 years :)... maybe...
And here are the specs:
Input
105-130 Vac 50/60 Hz 0.19A
Output
12 Vdc @ 1.00 Amps
Output
10.5 Vdc @ 1.3 Amps
Charge Voltage
14.0 Vdc
Float Voltage
13.4 Vdc
Desulphation Pulse
1.0A @ 3.26 MHz
Float Current
5 mA - 200 mA
Size/Weight
3-3/4” L x 2-1/2” W x 2-1/4” H / 2.3 lbs
Operating Temperature
0°F - 125°F - MEXICOWANDERERExplorerHow much is the TOTAL including shipping? I cannot access the Northern Hydrofunk website down here.
- Clay_LExplorer
otrfun wrote:
BatteryMINDer Plus $19.99
Great price on a great product.
Used one on my motor home to maintain the engine battery when parked and after 12 years it is still working. - Clay_LExplorerThe float charger at Harbor Freight is nowhere near the equivalent of the Battery Minder. It does not have the desulfation feature and the quality is much less. I tried the HF device on farm equipment batteries over the winter twice and both failed in a couple of months. I had been using a Battery Minder on my motor home to keep the engine battery charged while parked for several years and switched to one at the orchard. Still working fine after five years according to the new owner.
Specs for the Battery Minder.
BatteryMINDer® Model1500 includes full-time automatic high frequency pulse desulfation (not high voltage), which helps extend the life of a battery up to four times over its normal life. The unit can maintain up to four 12 Volt batteries at one time when connected in parallel by using SmarTechnology™ Y-Connectors (part# 210AY) or customer supplied 18-Gauge insulated wire - BobboExplorer IIHe is talking about this generic version.
- darsbenExplorer II
midnightsadie wrote:
$6bucks harbor frt.
SHOW ME - midnightsadieExplorer II$6bucks harbor frt.
Having RV issues? Connect with others who have been in your shoes.24,205 PostsLatest Activity: Feb 23, 2025
