Itinerant1 wrote:
Mobilesport wrote:
Furnace was just recently rewired srraight to the battery because furnace was acting up and so i quickly wired it straight to battery with thicker cables because very cold that day and needed heat asap.
Fridge is wired to the shunt
Not sure which furnace you have my Suburban 35,000 btu draws 7a while running no give you an idea.
Planner 44d diesal heater , it was drawing around 2.5 amps on the medium setting , 2 amps of lights on , then fridge but I don't know what the fridge would be doing
