How can you use a Trimetric monitor with a BB?
You can set the 100AH as your capacity, and set the charging efficiency for Li, you can make 14.4 your target voltage, and 4 amps your target amps for "full".
But the Trimetric uses the AH counter wrt the AH capacity entry for saying what the % SOC is. It does not use rising cell voltage.
Mobilesport was reading %SOC from his monitor based on the BB voltage vs % SOC specs, but his AH count was way off. A Trimetric would not do that. How did Mobilesport's monitor manage to?
