BFL13
Dec 10, 2014Explorer II
I have the time the 40a Vector takes to do a 50-90 on your bank of 470a. ( 6 hours) The charging profile of the VEC is not the same as other current- limited chargers, in that the voltage keeps rising during Absorption so that by the time it gets to 90% SOC the voltage will be about 14.5-14.6. It will reach 14.8 by the time it gets to 97% SOC and shuts off, saying FUL.
However that 50-90 time will be the same or shorter than another charger that does the classic rise to Vabs of 14.8 and then holds at 14.8 for the entire absorption stage. (ugly graph of VEC vs adjustable PowerMax)
So your comparison measurement has to be in battery SOC vs time, not by when each gets the batts to 14.8v. Other 40 amp cc/cv chargers should take about the same time as the VEC
That 6 hours is why, with a 458AH bank, I use 150 amps of chargers and try to get the 50-90 done in 2 hours. Of course you need enough generator to run the 150a and it helps if that is PF corrected so you don't need so much of a generator.
The VEC can be left alone to do it all including its Equalizing, because it shuts off when it is done. You don't need to babysit it. It has the amps read-out so you can tell when you are down to 5 amps per battery at 90% so you know you are done and can shut off the generator.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
