jrnymn7
Dec 11, 2014Explorer
sjturbo,
You may recall our discussion about voltages in your other thread. I just spent a few weeks trying to get my two 215Ah banks wired back to 430Ah's. It was a bit of a chore to get the voltages of the two 215's to balance out in parallel. But now they are resting at identical voltages throughout.
What I have noticed consistently is, my 6's react to higher voltages somewhat like a reverse peukert effect. After a good top charge at 15+ volts, their resting voltages drop significantly, and become unequal. And the voltages are unequal during the charge. But then if I follow up with another (gentler 14.8v) top charge, resting voltages come back up, and equal out; and voltages across each individual 6v are all equal during the charge, as well. So, just something to watch for.
That bank will easily handle a 100a charger during cc and cv. That's a C/4.7 rate... pretty much the same as my 45 amper on my 215Ah bank. At 14.8v, I see amps begin to taper at a little over 80%. This means a 100 amper would stay maxed out to over 80% soc on your bank.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
