NinerBikes
Dec 14, 2014Explorer
Empty Nest, Soon wrote:
I’m still getting to know the B&D VEC1093-BDB that I bought recently. If others are getting 14.8 or so volts maximum, I wonder whether there may be differences in different editions of the same model charger.
After charging the batteries with the on-board Heart inverter/charger recently, I took advantage of a good weather day yesterday to top-charge with the VEC1093.
On the house batteries, I set it at the 40-amp rate and it wasn’t long before it started tapering the amps input. I can’t recall that I checked the voltage with the initial charging. When it had tapered to the point where I was sure it was in Absorption mode, I found it was feeding the batteries 15.3-something volts. I got the same result with 2 different digital voltmeters. After 2.5 hours it had finished with top-charging 4 Deka Group 27 dual-purpose batteries.
I switched it to the chassis batteries. It immediately tapered the amps to a very small rate. Voltage was again 15.3-something. It declared the chassis batteries FUL within 10 minutes.
I did not run the Recondition or Equalize mode on either set of batteries.
Wayne
Wayne, now go measure the specific gravity of every cell on every battery, write it down, and post it up here, on your fully top charged Deka batteries off.
You are looking for all cells to be 1.275 or slightly better. Specific Gravity always trumps what voltage the batteries are taking when you shut the BD off.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
