BFL13
Dec 14, 2014Explorer II
The VEC has temperature compensation so that 14.8v is only for whatever they picked as the "nominal temp." Mine reads about 15.2 when ambient is just above freezing out. In summer it only gets to 14.6 or whatever.
You could take a battery inside where it is warm and try the VEC there (wait till it warms up to ambient)and see what voltage it does then.
The Paramode converter with TempAssure has its temp comp "nominal" at 60F ISTR. Some things use 77F/25C as the "nominal" temp for their ratings.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
