Grit_dog
Oct 01, 2023Trailblazer
If you’re using it for local use only (can’t imagine big road trips with a tiny wheeled trailer), first clean it all out and see if there’s a real issue.
Next, unless the races are trashed or severely worn, you can likely leave them in and just slap new bearings in, if the bearings are bad.
If you need to remove the races, it’s easy with just common hand tools.
Heat the hub hit with a mapp gas torch. Knock the races out with a socket (like from your socket set) that just fits inside the bore.
Or loan a tool or buy a bearing/seal install kit. I’ve never done that but have replaced probably 100 different wheel bearing races with heat, the right size socket and a bfh.
