Roadwheel's avatar
Roadwheel
Bearing puller for utility trailer
Hi,
I recently got a free 4x8 utility trailer. I pulled apart the bearings and the grease that is still there is red and black and some shades of brown. One has some chips of metal in the dust cap. I'm thinking I should replace the bearings.
Is there a bearing puller that will remove the races from the hubs? I've read about slide hammer pullers and I've seen the screw-type ones online, but I haven't read much about them being used for trailer bearings.
The bearing size is 30205, which is 25mm x 52mm x 16.25mm.
  • You're smart to have checked your "free" trailer. Good job.
  • Just use a brass drift and hammer to remove the races.
    It is soft and will not harm the race or hub.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
