MNRonExplorerSep 27, 2013Bearing TempsI just repacked bearings and replaced all seals last weekend. Today was first day towing again. It's gorgeous up in the UP!!! Beautiful fall colors and temp is still 70 at 10pm. Back to my questi...Show More
Old-BiscuitExplorer IIISep 27, 2013Bet if you went across a set of scales (loaded as you were) you will find a big difference in axle weights on trailer.I've seen those temps but not on a cool day.Check your brake adjustments also
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
Related ContentUneven Bearing TempWheel bearing repackingWheel Bearing Temp QuestionBearings packedQuestin on bearing hub temps
