Dusty_R
Oct 28, 2013Explorer
Follow the battery cable.
The isolator on our Itasca is very hard to get to. You open a storage compartment, remove everything, remove the back panel of the compartment. Behind that panel are some fuses, you remove the panel that the fuses are mounted on, and behind in is the isolator.
I had to replace ours once when we were on the road a long ways from home.
Good Luck,
Dusty
Good Luck,
Dusty
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
