jferre9570
Oct 28, 2013Explorer
On my '96 Beaver, the isolator is under the bed, bolted to the electrical panel under the foot of the bed. This isolator does not allow the inverter/charger to charge the chassis batteries however; it only allows the alternator to do so. The inverter charger should charge the house batteries but in order to charge the chassis batteries from shore power you will need a different method. Some models came with a BIRD-style controller, some with a Xantrex Echo-Charger, and some (like mine) came with no EOM way to charge the chassis batteries from shore power. Do you have your wiring diagrams?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
