allenm's avatar
allenm
Bedroom AC Outlets Loose Power
I have a 2016 Starcraft (part of Jayco) trailer. It has two AC outlets in the bedroom. Sometimes both loose power. When it happens, everything else on that circuit still has power.
Here's what I found out so far. They are the same circuit breaker as the frig and GFCI outlets in the kit, bath and outside.
The GFCI is in the bath. If I trip it, I loose power to the bath, kit and outside. The frig and bedroom still have power.
I have quite a bit of electrical experience and know the dealer isn't likely to fix this on the first try, which is why I'm working on it.
I'm wondering if anyone has an idea where Jayco/Starcraft usually connects non-GFCI outlets into a circuit with GFCI outlets?
  • The horribly cheap push on outlets mfg use are the cause of most electrical problems. Go buy a bunch of quality outlets and start replacing the garbage.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
