wa8yxm
Sep 22, 2019Explorer III
What make and model I know two slides but there are 4 I"m fairly sure you do not have the 3rd on my list but if you have the 4th I can't help you
Power gear the motor turns a transmission. they can break, the transmission turns a round shaft. a square shaft fits over it with a 1/4 inch hear pin (Grade 8 bolt normally but can be a roll pin) the other end of the square shaft drives another round shaft, via another shear pin, this shaft drives the gear.. and you guessed it. another shear pin.
Accu-Slide the motor drives a transmission which drives a gear that pulls chains
HWH Hydraulic (You described a different system)
Sweintec (Just call me Shults.. I know nothing
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
