aedds2's avatar
aedds2
Bedroom Slide Not Retracting
We have a 2009 Jayco Seneca 36MS and having problems with the bedroom slide not retracting. It went out fine. We hear nothing from the motor and the in/out panel is flashing. Read that there is a 25amp fuse that's hidden or it could have lost it's memory.
Any help or experience fixing this issue?
  • Have tried to learn why my bedroom will not retract. It is a lippert hydra gear hydraulic unit. Think it is the cylinder or ram. Tomorrow am going to try and close bedroom valves and see if that will close the living room slide. My thinking is if it does close the living room that will indicate the cylinder is bad for the bedroom. What say you forum?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    You might tell us what kind of slide out it is Accu-slide. HWH. Power gear Swintek.. I know 2 of them very well,, can help with the third and have no clue on Swintek.
  • Having a simliar issue with mine. If you don't hear the motor you may have a weak battery or there may be a bad circuit breaker.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
