time2roll
Oct 31, 2017Nomad
valhalla360 wrote:If you are over 40 mpg that certainly helps on reducing oil consumption.time2roll wrote:Run the numbers and overall cost will be far lower with an inexpensive high MPG gas powered car.
The best way to reduce prices is to drive an electric vehicle when not in the RV.
Doing my part since 2011. Either be part of the solution or be part of the problem.
JHMO
The best option is just to stop traveling...so are you part of the solution or part of the problem?
Electric vehicle all but eliminates oil consumption.
This was not entirely about low cost but to reduce or eliminate oil consumption.
Lowest cost is a $100 4 cylinder beater.
