RJsfishin
Sep 29, 2015Explorer
What ??? Did chris need reinforcement from you ?
I know who both you guys are, and neither of you are "know it alls", even tho you pretend to be at times.
If someone has a easier, faster, and less expensive way to fix something, I've learned to listen !
dougrainer wrote:RJsfishin wrote:
Quote:
The correct way would be remove the piece, straighten and replace, resealing the whole thing. Otherwise you are just putting band aids on it, hoping it will be OK
Not hard to tell that this comment come from one that knows nothing about metal fabrication and repair.
There is no shop (RV or otherwise) that will take that apart to fix it !
I suggest you research WHO Chris Bryant is. I am NOT a metal fabricator, but to CORRECTLY straighten that slide flange, you do exactly what Chris suggests. THAT is what I have done when a customer wants it repaired back to factory original. BUT, as I stated, you can seal that gap caused by the bend without doing the complete repair as Chris suggested. I would inject Dap into that void, and take a mallet and beat the void inward with the DAP oozing out. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
