BFL13
Oct 12, 2020Explorer II
pianotuna wrote:
Phemens,
An SiO2 100 amp-hour would have been $600 Cnd and would offer essentially the same performance as Li. On float, lifespan is 18 years.
The Li has the advantage of not being so heavy, which matters in some RVs.
The Si has the below freezing operating range advantage for those that need that. There may be other factors for each type to consider.
600 vs 700 may not be significant. If you can afford the 600, you can probably afford 700. It is more a case of "horses for courses" IMO
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
