time2roll
Jan 10, 2017Nomad
If you have no expansion tank, just listen for the water pump.
If you have an expansion tank, remove it or remove the air for diagnostics.
If you are worried about a special area you can get a battery powered water sensor/alarm.
Otherwise periodically look under the RV for a wet spot.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
