MarkieBob
Jan 11, 2017Explorer II
dougrainer wrote:
The RV systems are designed to be OK in 100 psi. What PSI are you thinking is a problem? The standard CG or supply PSI is around 50 to 60 PSI and the RV pressure regulators give you 45 PSI. Doug
I've had pex line fittings develop a VERY slow leak--some of which are not visible (like under shower). The pump may or may not cycle for these. I just thought a device to monitor slight fluctuations might be helpful.
BTW, I bought the MH new. My trusted rv repair dealer in fixing a small fitting leak was concerned who put the fittings in as they were not done correctly. He was surprised when he learned that I bought it new
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
