- HiTechExplorer
harold1946 wrote:
One of the main reasons for early failure with all PV made by Unisolar is that the protective coating for both their rigid and flexable panels is plastic. UV destroys plastics, and it has to pass through that before reaching the cells.
Actually I think it's the other way around. I believe the plastic lense on the front of Unisolar units is heavily UV stabilized, resulting in the lower efficiency rating per square meter, because some of the light energy is absorbed by the stabilizing additive in the polymer coating.
UV stabilizer
Jim - harold1946Explorer
MrWizard wrote:
well i have a roof top nearly covered, with 'second hand' unisolar frame mounted, no glass or plastic
except for what ever is covering the cells
and they work great
and when i clean / wash them off, their coating looks clear, no aging , no fogging or yellowing
i don't know what you mean by 'early'
prototypes ,or first run?? , a few of mine are ten years old, still produce full power
WRONG!! Unisolar panels all have some type of plastic coating to help protect the cells.
If need be I may be able to research what type of plastic was used, but most of their materials and processes are patented and held by the parent company. - MrWizardModeratorwell i have a roof top nearly covered, with 'second hand' unisolar frame mounted, no glass or plastic
and they work great
prototypes ,or first run?? , a few of mine are ten years old, still produce full power - harold1946Explorer
MrWizard wrote:
as i recall
unisolar panels will convert uv to electric
they don't need uv protection
iirc they convert light of three different spectrrums
yes they are almost twice the sq ft per watt than some new high power mono cystaline panels
But place two 60 watt panels one unisolar one mono crystal side by side in heavy overcast conditions and measure the output of each
i think you will find the unisolar will out perform the mc panel
that being said you CAN fit 120w of MC panel in the same space as 60w of unisolar panel
i do not know whether that 120w will produce more power than the 60w unisolar under the same heavy overcast
it has been said many times on this forum if someone wants the most watts from the available roof space get crystaline panels
but if your power needs can be meet by a set number of watts that can be obtained from thinflim like unisolar, then the unisolar will produce power when the others do not
and they are lighter and there is no glass to break
One of the main reasons for early failure with all PV made by Unisolar is that the protective coating for both their rigid and flexable panels is plastic. UV destroys plastics, and it has to pass through that before reaching the cells. - SalvoExplorerI thought we covered that question. Low light performance is too close to call on mono vs. poly. Your poly spec doesn't give low light performance. The mono spec shows low light performance similar to my Kyrocera poly panel.
There you have it. Go with the one that looks the best (warm tummy feeling).
Salpianotuna wrote:
Which is why I was asking about better performance of mono vs poly. I need to pack as many additional watts as I can into the remaining limited space. - harold1946Explorer
pianotuna wrote:
harold,
You ARE off topic. That topic is which is better mono or poly.
[COLOR=]That has been answered several times.
#1 Poly
#2 Mono
#3 Amor
My panels are deposited directly on metal. Should you wish to google about them you are welcome. The model number is US-64.
If you would not quote "out of context" it would help. I don't want more unisolars because they are huge. If I had enough real estate on the roof I'd buy them, in a flash. But I don't.
Show anywhere that what you have said has been used out of context. - pianotunaNomad IIIHi Salvo,
100% correct (as usual)
Which is why I was asking about better performance of mono vs poly. I need to pack as many additional watts as I can into the remaining limited space.Salvo wrote:
It never makes sense to go with Unisolar if space is limited. You need more than twice the surface area to get perhaps 6% more output during low light conditions. That's crazy!
Sal - SalvoExplorerIt never makes sense to go with Unisolar if space is limited. You need more than twice the surface area to get perhaps 6% more output during low light conditions. That's crazy!
Salbdosborn wrote:
The big difference is the 240 watt panel is ~18 sqf versus ~42 sqf for 248 watts of Unisolar panel.
Bruce - MrWizardModeratoras i recall
and they are lighter and there is no glass to break - pianotunaNomad IIIharold,
The active material on the panels are deposited directly on metal. Should you wish to google about them you are welcome. The model number is US-64.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 05, 2026
