path1's avatar
path1
Best way to charge batteries when Boondocking?
(little bit long but I don’t want to miss any details)
I pull my 29 foot(30 amp)cord from the left rear of trailer to the hitch area where the generator is located at the back of my pick up and then I plug in 30 amp cord.
Then elec goes 29 feet through 6 awg wire to a progressive dynamics convertor also located in rear of TT, but on right side of TT. So add another 7 feet. Then the convertor sends the elec back again 29 feet to the 12 volt batteries on the front hitch.
Wouldn’t it make more since to just hook the generator up on the DC side to batteries and save 65 feet? Or through a portable battery charger?
One person said it is better off charging the batteries through the converter/charger. Because you are running AC to the converter, voltage loss is not generally an issue.
Another person told me, elec routing is always the shortest trip the elec will have to make.
Could I charge batteries faster using the 30 amp cord and a portable battery charger?
As you can tell I’m confused. What are your thoughts on best way to charge batteries?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
