Kayteg1
Apr 23, 2016Explorer II
Research what converter you have.
Most of them are cheap, inefficient and easy to overheat.
I just measured my converter takes almost 3 amp @120V when all the breakers on it are off and battery disconnected.
"Power that goes nowhere"
Than the build-in charger goes over 14V what on long run will boil batteries and overheats very easy with high charging current.
The best way for charging I figure out is to take my computerized 25amp charger and power it from 800W generator that Harbor Freight sells for $89.
This way you have efficient charging without danger and don't wear out expensive generator. (I also like to have back-up and light generator fits the bill just fine)
Obviously I am timing generator run with using my coffee maker or running microwave.
The 800W generator handle both just fine.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
