DrewE
Aug 16, 2015Explorer III
I'd use a ring terminal held on with a bolt and a flat washer/split lock washer/nut. The ring terminal and the battery terminal should be in contact, with no washer intervening, assuming a permanent attachment. For a battery charger or similar temporary connections, I see no reason why the usual alligator clamps would not be perfectly adequate.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
