pkunkExplorerAug 16, 2015Best way to connect to Battery FL1 terminalWhat is the Best way to connect to Battery FL1 terminal? Should I just use a nut/bolt/washer or is there a better way?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
Related ContentQuick connect exterior shower hose doesn't connect.Connect fuse directly to battery terminal?AG battery switchoverCan you use all terminals in parallel connection?Connecting 2 batteries together
