pianotuna wrote:
Gdetrailer,
Is your roof flat? Mine is curved. I like the aluminum idea.
dougrainer,
Redecking sounds expensive. But I do value your advice.
My roof has the typicalRV slight curve so it is about 1 inch higher in the middle than the sides. It actually started out it's life with a aluminum roof, but the previous owner tragically shot thousands of little tiny air nails through the roof as they attempted a repair/remodel that was a epic fail. Moral of story, don't use powered nailers when remodeling a RV, you can't tell if you hit the narrow studs or blew through them..
5 yrs ago I did entertain covering with aluminum roofing, but as with even the membrane roofs the issue became finding a place that was willing to order and have the capability of receiving over sized freight via semi trailer.. Basically has a shipping dock.
I had neither a means to be at home at time of delivery or a shipping dock which would make life easier at the time. I was working at a place which has a shipping dock, but management frowned on having personal non business shipping hit the docks and working there for many yrs had to deal with a lot of materials that got lost on the dock or damaged on the dock..
Both aluminum rolls and roof membrane large enough to cover in one piece (too make for a seamless roof) requires truck shipping and consider that the roofing will mean at a minimum of 9ft wide roll I found that Peel and Stick to be a good compromise which allows for normal carrier shipping and handling.
Right now, I would hate to see what a large one piece run of aluminum roofing would cost :E
The Peel & Seal is designed to be applied to flat or pitched roofs, it works so well for us that when we needed our house reroofed, the roofers mentioned that our dormer had too small of pitch for shingles.. They recommended a "cousin" of the Peel & Seal which is a self stick black rubber/asphalt membrane system that is then covered with a second self stick membrane which has the roof gravel on.. The beauty of the self stick is there is no nails, screws or any fasteners needed to go through it. Has another benefit, it is "self healing" if one needs to run a screw or nail through it, the rubber/asphalt makes a water tight seal around the screw or nail.
I have also used Peel & Stick as a "flashing" and seam sealer on my metal garage roof which started leaking at the seams in places..
I would prefer something a bit more lifetime permanent like one piece aluminum, but so far the Peel & Seal is working great for me.
