mlts22's avatar
mlts22
Explorer II
Jul 10, 2013
Best way to splice into a 12 volt wire?
For splicing into existing 12 volt wiring, what is the best way to do so? Best as in resistant to vibrations and won't burn out?
I have seen 3M Scotchlok connectors, but I wonder how secure they will stay over time.
Soldering is also an option with heat shrink tubing.
Of course, there are crimp connectors, but can someone recommend a good crimping tool? So far, the ones I've used, one has to be careful with or else it will cut the crimp joint in two. To boot, wires seem to work loose over time.
