MrWizard
Jul 10, 2013Moderator
splicing for 'what' ?
location , wire size, and load dictate what can be done, which may not be optimum which can be done in a easily accessible location
if it is to be permanent soldering is best
next crimped with a hydraulic crimper
next use a 'split bolt' connection and tighten fully, before taping and sealing
something you might want to change
split bolt is best
next is solid 'wire nuts', not the soft scotch lock type
the only time i will use the soft ones is if that is the only thing available, and time is of the essence, then i will replace them with the good kind
split bolt is best
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
