time2roll
Jul 10, 2013Nomad
I have and use these multiple wire heat-shrink crimp butt connectors.
Waytek wire
I would trust these in all conditions. The usual issue with butt connectors is getting the right size to match the wire. If you try to jam in multiple different mismatched wire the crimp can be poor. With the correct connector the crimp is not as critical. It just works. Heat shrink will prevent all stress from compromising the joint.
Soldered connections are very rare by a chassis manufacturer. Solder is for circuit board stuff. A mechanical connection is generally preferred by oem.
Splice kits for large wire
Waytek wire
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
