uintafly's avatar
uintafly
Best way to test for cracked water lines
First off I have to acmit to being paranoid about water leaks. Water (in the wrong places) seems to be the biggest destroyer of a good RV, so I am paranoid about it. Maybe too paranoid.
We camped this weekend with forcasted lows to get around 28-30 degrees, which didnt really worry me. And Friday night probably got to around 28 with no problem. the second night however the temp dropped probably to close to 24 and was below freezing for around 10 hours. The only thing that seemed to freeze was the fresh water drain as it is exposed to the weather, but there seemed to be no harm done. There was also no sign of leakage anywhere else. but we went home fairly early that day and didn't really use much water in the morning. I blew out my lines later that night as we will drop into the high 20's for the next few days. But yesterday I started wondering about the outside shower, and the lines that while inside the coach run under the shower and right along the outside wall. Even though the heat was on all night is there much chance of leaks?
I also went last night and closed all the faucets and ran the pump dry for a couple minutes just to get some air pressure in the lines to test this morning, and there was no pressure this morning. I am assuming air pressure acts different than water pressure, but I would have felt much better if there was still some built up pressure. As I being overly paranoid or is there a chance of a leak?
Thanks,
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
