MarkLDN
Sep 16, 2016Explorer
MEXICOWANDERER wrote:
Called a wire TRACER bumpy :)
I would treat the white wire as being a negative as coach builders even back then used white as negative. Yellow was favored as a positive or switched positive wire. RV wiring nightmares are caused because there is no consensus with the industry. This invites government intervention and regulation and higher costs. Utterly stupid when a wiring standard much like the old, marine, YSC, could be adopted at zero cost. And people wonder how and why our government is out-of-control. Snarf, grumble, snarl.
Thanks MW! I have reason to believe the white is a ground as well. I can't comment on the regulatory creep / no-creep! Haha.
Also thanks to the previous poster for the device recommendation. If ohms test fails then i'll go buy one.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
