Cameo_Phil
Jan 01, 2018Explorer
Be careful with using silicone for electrical connections. For electronics and anything liable to be corroded you MUST use "neutral cure" Silicone rubber.
You can buy acid cure Silicone Rubber which exudes acetic acid as it sets.
If it smells like vinegar then it's acid cure. Acid cure Silicone will corrode electrical connections in short order.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
