Bobbo's avatar
Bobbo
Explorer III
Jul 28, 2021
Best weatherproof MPPT solar charge controller
I am about to buy 200 watts of portable solar panels in a suitcase configuration. I was about to get a Renogy 200 watt unit that comes with a weatherproof 20 amp PWM controller, but I really want an MPPT controller so I can hook those panels up in series rather than parallel. That way I can reduce voltage drop by carrying half of the amps at twice the voltage, and putting the controller beside the batteries instead of beside the panels. Then I had a brainstorm. Instead of buying the 200 watt unit with a PWM controller that I don't need, and wires I have to cut and reconfigure to get series panels, I will buy two of their 100 watt suitcases without a controller. That will make it easy-peasy to put them in series configuration. However, I still need a weatherproof MPPT controller.
Question, can someone point me to a decent weatherproof MPPT controller, preferably negative ground? (Victron doesn't list any of theirs as weatherproof.)
Thank you in advance
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
