Gdetrailer
Jun 27, 2021Explorer III
Pleated filters like that are considerably more restrictive to air flow than the original washable foam filter.
It is good that you checked air flow but even a slight restriction under the correct conditions may result in the A/C cools to freeze up into a solid block of ice much faster than they would otherwise.
I use those filters on my wood burner fan box to reduce wood ash from getting blown through the house. I modified the fan box to use two filters in fact side by side and even that causes a noticeable change in air flow.
I won't even consider them on my home furnace, causes the furnace to trip the overtemp limits once and a while..
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
