burlmart's avatar
burlmart
bidirectional isolator relay delay and voltages
for those with motorhomes that have B.I.R.D.s, do you find that you get inaccurate or misleading voltage readings from your house battery and your chassis battery. for instance, readings that differ and fluctuate at odd rates depending on house battery disconnect toggle (STORE/USE}.
i have attempted to express some weird things i seem to encounter when doing so on this thread from the C forum. as confused as i seem here, a few years ago i went through similar issues before i'd ever hears of BIRD. to my great relief, another trail lite owner discovered we both had one in our rigs.
at this point, i am resigned to just try to ignore voltage readings and simply try to make it a point to give batteries ample shore power charge time from the parallax 7300 between RV outings.
but it would be somewhat of a relief to hear from others that a) i am not imagining things, b) i need to expect unique voltage sharing/interaction w/ the BIRD relay/delay and chassis isolator solenoid, and/or c) my system has a problem that can be tested by doing X.
i thank you for any insights and clarity.
  • Keep in mind the BIRD and the disconnect are 2 separate systems, not interconnected (other than battery wise) The voltages indicated on the disconnect could be flaky simply due to a dirty switch on the panel. The BIRD simply measures the battery voltage of either battery, and connects them when the voltage indicates charging on either, with a delay built in to let the alternator get a bit ahead of the curve.
  • CA Traveler wrote:
    Why don't you simply bypass the solenoid and post the results?
    not clear on what you mean.
  • Mine is rock solid. Unlikely that BIRD and your solenoid are the problem, perhaps your charger but I'm not going to read your other thread which quickly suggested your charger might be marginal.
  • i've found over the years that the BIRD device is not discussed much on these or other rv forums, but as far as i understand, it is used in many motorhomes.
    to those who understand the innards of electronic gadgets, can i just assume the BIRD device seldom fails to do its gatekeeping duties and just forget about it, much as we take for granted something like spark plugs?
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
