red_ranger's avatar
red_ranger
Big Buddy heater problem
When i use the heater with 2 1# bottles, the bottles freeze up and the heater stops working with the bottles maybe half empty. what am i doing wrong?
  • Thanks beemerphile that has to be an improvement. Its not acceptable that a heater won't work cause its too cold. We rarely boondocks in the cold so not worth the trouble to plumb it in, at least thats what DW says!
  • First thing would is leave the covers open. I have had frost on them but never stopped flowing fuel.
  • red ranger wrote:
    I guess we will get extra bottles and another blanket !
    Yep, prolong the misery, thats the answer ??
    Why not pretend its an OlyCat and plum it into the big tank ?
  • We have run ours off a permanently plumbed hose into our MH system. It goes into the low pressure quick connect port on the big buddy. This has worked great for years. I know it should be able to be run off the small bottles, but the smaller the bottle of propane the more likely it is to freeze-up.
    We can get a very long run time with the 20 lb. tank.
    Good luck
  • tvman44 wrote:
    Apparently they are too small and the quick withdrawal of fuel the temp drops too low and it freezes up. IMHO get a larger tank. :)
    X2, or drop the unit to the low setting after getting it going. It may keep the freeze-up from too much draw from happening.
    x2
  • Apparently they are too small and the quick withdrawal of fuel the temp drops too low and it freezes up. IMHO get a larger tank. :)
